Old 01-31-2014, 10:05 AM   #2
Chris in CT
Default Re: lightened flywheel
Hi Calvin, Two reasons for the 62 lb flywheel (stock) are: 1. The extra weight serves as an impulse dampener for the non-counterweighted crankshaft; 2. the extra weight allows "set it and forget it" ignition timing in the lower compression antique engine.
When to lighten the flywheel? 1. When the engine has a counter-slung (balanced) crankshaft where impulse dampening occurs directly under each cylinder; 2. When the compression ratio is raised significantly.
Please note unintended consequences of 2. above: If you raise the compression ratio and lower flywheel weight, you will need to play with ignition timing while you are driving, or add a centrifugal-type timing control to your distributor. Some of the guys have complained that they lose power on the hills with the lightened flywheel, but I have found that is not at all the case. But I do have to fiddle with the spark lever until I find the "sweet spot" for climbing a hill with my own '29 roadster (counter-slung crank, 5.5 head, and 40 lb flywheel).
I'm sure that some of the other guys will have something to add to this...
Happy Motoring! Chris
Chris in CT is offline   Reply With Quote
