Old 01-06-2014, 02:02 AM   #1
Rubatoguy
Rubatoguy's Avatar
Default JB Weld on crank end housing?
I pulled the flywheel on my model A engine and found this - It looks like the rebuilder used JB Weld to form half of the end of the crank end bearing housing. Is this done very often and an accepted repair?
Todd
Rubatoguy is offline   Reply With Quote
Old 01-06-2014, 02:47 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: JB Weld on crank end housing?
Todd
No and No way!
Old 01-06-2014, 03:20 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I can't figure out what he was trying to accomplish. Also what do you have screwed into the crankshaft? The threads sure look rough.
Old 01-06-2014, 03:24 AM   #4
darrylkmc
darrylkmc's Avatar
Nothing looks right about any of those holes, to me
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 01-06-2014, 07:07 AM   #5
James Rogers
James Rogers's Avatar
That's a frikkin' mess! I wouldn't EVER let that guy fix so much as a candle.
James Rogers is offline   Reply With Quote
Old 01-06-2014, 08:11 AM   #6
newshirt
newshirt's Avatar
You have his fingerprints. Prosecute!
Ray White
newshirt is offline   Reply With Quote
Old 01-06-2014, 08:37 AM   #7
steamgas
steamgas's Avatar
also look at the big hammer mark on the flange.ain't no way a flywheel would set down true on that surface.
steamgas is offline   Reply With Quote
Old 01-06-2014, 08:59 AM   #8
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
I'm a bit surprised as usually everyone sings the praises of JB weld in this chat room.
it seems that you may have a defective rear main cap or they couldn't get the slinger to fit right in the main cap? Clearly it would of been better to get another rear main cap rather than slap it on with a putty knife. The crank flange also is damaged with the big dent in it. Oops.!
I would contact the rebuilder if they are still in business and get your engine straightened out.
J and M Machine is offline   Reply With Quote
Old 01-06-2014, 08:59 AM   #9
Tom Wesenberg
At least the guy left his fingerprints in the JB Weld, in case we need to get Perry Mason in on the case.
Old 01-06-2014, 09:07 AM   #10
Kurt in NJ
Kurt in NJ's Avatar
The dowell pins usually stay in the crankshaft ---it's hard to see in the picture, but it sort of looks like the dowell holes are threaded --perhaps there was a problem with the flywheel bolts and longer ones were tried, they were too long and that created the need for the repair. ----was the dowell retainer plate there when it was taken apart, how many bolts were there (should be 4)
Old 01-06-2014, 09:31 AM   #11
Keith True
Keith True's Avatar
I use a couple of old head studs in the crank like that to wiggle the flywheel off with.When it breaks free of it's nice seat against the flange I'm not trying to rassle 63 pounds all of a sudden.If I'm pulling an engine apart I throw one long stud into the crank like that too.It is easier to muckle onto that skinny stud to pick the crank up than to try to hold onto fat crank throws with oily fingers.
Old 01-06-2014, 09:33 AM   #12
Tom Wesenberg
It looks like the same light colored JB Weld is on the rear main area of the block also. You showed the wear on the piston. What else has been found? Are the water jackets clean? Check the cam lobes and tappet diameters. At this point everything about the engine is in question.
Old 01-06-2014, 10:19 AM   #13
tbirdtbird
"everyone sings the praises of JB weld in this chat room"
Not me !!!
'31 180A
tbirdtbird is offline   Reply With Quote
Old 01-06-2014, 10:49 AM   #14
Rubatoguy
Rubatoguy's Avatar
So for the mystery of the studs, those are engine studs that I used to support the flywheel as I screwed a long cap screw though the starter mount to walk it off the crankshaft. If you look at my other posts, you can see the other items I have found with this engine. It was rebuilt by a so-cal well-known rebuilder in the 1980's and never ran correctly from the get-go. The car sat for many years, and I inherited it and am trying to get it into running condition.
Todd
Old 01-06-2014, 10:55 AM   #15
tbirdtbird
A noble cause! We will help you. Also, get some resources, such as Les Andrews series or search this site for other suggestions. Reference manuals can be a huge help. Search this site; there is a ton of knowledge already archived here.
good luck!
'31 180A
Old 01-06-2014, 12:19 PM   #16
V4F
V4F's Avatar
is it to seal the rear main ?? it sure looks like it .
V4f
V4F is offline   Reply With Quote
Old 01-06-2014, 02:39 PM   #17
Barry B./ Ma.
Barry B./ Ma.'s Avatar
The threaded post may just be used to support the flywheel when removing it. That dent will make the flywheel wobble.
Barry B./ Ma. is offline   Reply With Quote
Old 01-06-2014, 04:24 PM   #18
John Stone
John Stone's Avatar
Is the rear main cap on backwards or am I seeing things?
John Stone is offline   Reply With Quote
Old 01-06-2014, 05:11 PM   #19
H. L. Chauvin
Be nice!
Can't anyone see that the flywheel was originally wobbling, the scientist-mechanic had no shims, so he ingeniously kept hitting the crankshaft with a big hammer until the flywheel was true & quit wobbling.
Wait for the next photos to see how this chemistry-minded professor also tightened the connecting rod bearings by adding J.B. Weld mixed with mercury & smeared it on top of the Babbitt with a putty knife..
H. L. Chauvin is offline   Reply With Quote
Old 01-06-2014, 05:58 PM   #20
1931 flamingo
1931 flamingo's Avatar
I was reading a thread on the EV8 forum about endplay on the crank. Some were talking about welding and then machining on the crank. Is that possible on the A's crank or not. I'm thinking excessive end play contributes to rear main leaks??
Paul in CT
