Old 12-29-2013, 09:19 AM   #1
John Kuhnast
Default Re: Master Cyl, which one?
I used an early mustang. Its small and fits in nice. Be sure to get the one for shoe brakes all around because some are disk on front. When you try to bleed them the air goes to the other end. Bleed the back the air goes to the front. Bleed the front the air goes to the back. What we did was onhook the front and install a plug.Bleed the back then connect the front and bleed the front.
John Kuhnast is offline   Reply With Quote
