Old 12-08-2013, 02:32 PM   #1
Ralph Moore
Ralph Moore's Avatar
Default Question about windshield hinge
Getting ready to put my windshield in, but it seems something is not right.
The hinge has two places where the metal is bent up( on purpose) for reasons I can't figure out. If I mount it like it is then the screws around this area will pull the rest of the hinge in a bind and the entire hinge surface will not be flat and twist.
_____/---\_____________/---\______
Kinda looks like this
I'm i missing something?
Ralph Moore is offline   Reply With Quote
Old 12-08-2013, 03:42 PM   #2
wrndln
Default Re: Question about windshield hinge
What kind of car and year are you working on?
Rusty Nelson
Old 12-08-2013, 04:32 PM   #3
Ralph Moore
31 coupe,
It would seem to me that the hinge would fit better if it was flat from one side to the other.
Old 12-08-2013, 04:55 PM   #4
BudP
BudP's Avatar
I just hung a front window into a 1931 coupe. The hinge was flat. Your common sense is correct. The real problem is the windshield frame gasket. It's slightly thicker than what you removed and makes fitting the window at the bottom a problem. A better solution might be a butyl compound: never silicon.
BudP is offline   Reply With Quote
Old 12-08-2013, 07:58 PM   #5
Marco Tahtaras
Marco Tahtaras's Avatar
If you are talking about the rubber seal above the hinge forcing the windshield too low, that problem is typically caused from the installation of new header wood. It's kind of a moot point at this stage of the game but I wrote about that here about a month ago.
I agree about the flat hinge but sure would like to see Ralph's hinge in question!
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 12-09-2013, 09:16 AM   #6
Ralph Moore
I'll see if I can get a picture posted, all I have now is this phone and it doesn't work most of the time(posting pictures that is)
I have not bought my seals yet, any recommendations?
Old 12-09-2013, 10:50 AM   #7
Kevin in NJ
I had a guy that could not get the windshield to close.
Turns out the header wood did not fit the cover pan so the pan did not fit flat to the wood.
Something to check at this stage.
Old 12-09-2013, 12:42 PM   #8
Ralph Moore
I had the same problem, I had to trim the ends of the metal header cover so that it would go back far enough for the screw holes to line up and the windshield screws to not be hitting thin air.
Old 12-15-2013, 12:53 PM   #9
Ralph Moore
lets see if this works, here is a picture of my hinge, I
think I may have to flatten this to make it work.
Old 12-15-2013, 01:28 PM   #10
Ralph Moore
looks factory to me, like it was bent in a press, and they are evenly spaced, and the width of the hinge fits properly. Seems to me it would be shorter in length if someone did this to the original one.
Old 12-15-2013, 01:52 PM   #11
Roger V
Roger V's Avatar
Also never saw one like it. Hard to see but the frame looks like it doesn't have a draft deflector. Therefore, the windshield assembly isn't original.
Roger V is offline   Reply With Quote
Old 12-15-2013, 02:10 PM   #12
Ralph Moore
By "draft deflector" do you mean the large flange at the bottom that covers the slots in the dash rail when the windshield is closed?
Old 12-15-2013, 02:35 PM   #13
Ralph Moore
Here's another strange thing, when I put the garnish moldings in and mock up the windshield the brackets for the swing out arms hit the garnish and don't allow it to close all the way.
Old 12-15-2013, 02:45 PM   #14
Ralph Moore
Looks like I have a 28-29 frame, if I change the brackets for the swing out arm, will it still work?
Old 12-15-2013, 03:46 PM   #15
Canuck64
Deflector flange across bottom has to be trimmed to clear windshield posts, as per Marco's pictures. Also slider arm brackets have to be changed to 30-31 that extend closer to center of car. Those brackets can't be extended with spacers, ask me how I know.
Canuck64
30 Ford Coupe Build “ http://chevelle406.wordpress.com/
UPDATED JANUARY 7, 2014
Canuck64 is offline   Reply With Quote
Old 12-15-2013, 04:20 PM   #16
Ralph Moore
Thanks Canuck, I have already trimmed the flange as I have a 36 dash mounted in my car. I'll see if I can come up with a pair of those brackets. And I guess I will have to flatten the hinge as well.
Old 12-15-2013, 05:42 PM   #17
Ralph Moore
That's the ticket, and I don't have to look for another windshield,
Thanks
Ralph
Old 12-15-2013, 07:47 PM   #18
Marco Tahtaras
I believe that upper hinge will present numerous other issues as well. Look closely at cross section shape of Coupe's pic I reposted here.
Old 12-16-2013, 09:58 AM   #19
Ralph Moore
other than the taper at the end, I don't see the difference.
Old 12-16-2013, 02:56 PM   #20
Marco Tahtaras
Ok, now I can see better. It's been a LONG time since I helped with a '29 windshield install and was thinking the hinge was different. Your first pics had me confused as I didn't realize it was still attached to the top of the frame. Sliding the hinge apart is one of the first things most folks do.
