Old 12-07-2013, 10:30 PM   #1
31 RPU
Default Adjustable Tappets
Has anyone tried the split bolt adjustable tappets? They don't have a jamb nut.
Do they stay adjusted once they are set?
Thanks
31 RPU is offline   Reply With Quote
Old 12-07-2013, 11:05 PM   #2
midgetracer
midgetracer's Avatar
Default Re: Adjustable Tappets
I have had no problems with them.
midgetracer is offline   Reply With Quote
Old 12-08-2013, 12:36 AM   #3
MikeK
MikeK's Avatar
I have had problems with two. You are between a rock and a hard place, the double locks have a smaller foot diameter that is not compatible with some cam grinds. I disassembled, degreased, tightened the fit, and then bead blasted the threads on the last two new sets I have used. I also re-dressed the bolt faces, as the surface was not a true flat interface to the valve stem.
MikeK is offline   Reply With Quote
Old 12-08-2013, 04:19 AM   #4
Mike V. Florida
Mike V. Florida's Avatar
Same here, many years, thousands of miles no problems.
