Old 11-19-2013, 01:51 AM   #3
700rpm
700rpm's Avatar
Default Re: cooling system
You should be able to see water in the upper tank when you remove the cap. Fill it up, but not all the way to the top. The water will find its own level as you drive. But if you're steaming, you've got a problem somewhere in the cooling system.
Ray Horton, Portland, OR
