Old 10-31-2013, 03:44 PM   #1
jon laing
Default 1939 ford radio
I am considering installing a "Secret Radio" in my 1939 ford. The advantage is that most of the equipment can be installed under a seat or hidden behind the dash. This keeps the car looking original. Does anyone have advice or experience with these radios. I am primarily looking for a good AM/FM up to date radio. Jon Laing
jon laing is offline   Reply With Quote
Old 10-31-2013, 04:16 PM   #2
CaliforniaBorn36
CaliforniaBorn36's Avatar
Default Re: 1939 ford radio
You can search "Radio Solution? Secret/Hidden Stereo? " or on my user name and see a thread on this topic. Lots of options and opinions. I have some additional informaiton on another computer that I will look at this evening and add here, about some other radio alternatives if you are interested. I am thinking underseat.
CaliforniaBorn36 is offline   Reply With Quote
Old 11-06-2013, 01:15 AM   #3
cryobug
I installed a radio in the panel between the trunk and the passenger compartment on my 39 coupe and control it with a remote. The radio has a USB port on the radio and I have all of my CDs on a memory stick.
cryobug is offline   Reply With Quote
Old 11-07-2013, 03:49 PM   #4
CaliforniaBorn36
John, I have been considering tunes for my 36 for a while and have done some research, If you are installing in the Glovebox anyway, appearance of the unit is less critical. I tried looking up the USA230(?) radio you mentioned in another post and it looks pretty expensive. A few other alternatives I found are
http://www.amazon.com/Pyle-PLMRKT12BK-In-Dash-Marine-Tuning/dp/B002J9GHHA
http://www.amazon.com/Pyle-PLR14MPF-In-Dash-FM-MPX-Shaft/dp/B004HJ3FH0
Both a lot less expensinve and the one in kit form even has a remote and marine grade speakers.
Post back on what you end up doing, I'd love to hear what you think of the final result
Power converters are available on Ebay for the 6 to 12 volt, positive to negative ground issues if you are still running 6 volts
Matt
Old 11-07-2013, 04:17 PM   #5
Old Henry
Old Henry's Avatar
If you're still 6 volts like I am you may be interested in what I did.
As I was considering a sound system as an alternate to my AM radio I thought of doing what you're thinking but that would have required a 6 to 12 volt converter for about $100 plus the rest of the system. Instead, I just bought a headphone amp for about $100 that ran on a 9 volt battery then hooked it up to my radio speaker through a switch mounted in the roof of the glove box that I could switch the speaker source between my radio and the headphone amp and pluged the headphone amp into my DiscMan CD player and put it all in the glove box. I soon discovered, however, that running the speaker on the headphone amp soon killed the little 9 volt battery so I bypassed that and hooked the little amp up to a 9 volt battery pack I made out of 6 D cell batteries in a Radio Shack holder as shown. It lasts for a year or two. Because the single radio speaker is monoral rather than stereo as comes out of the CD player and goes through the amp I added a Radio Shack adapter wire that goes in stereo one end and combines both tracks into one monoral signal coming out the other end for the speaker. The system was somehow picking up the spark plugs so I got the choke coils from Radio Shack and put on all the wires to eliminate that. So, basically for the same as I would have paid for the 6 to 12 volt converter alone I had at least a CD player that played through my radio speaker. Whenever I take guests for a ride I put on 40's music and they wonder what radio station I'm playing that old music from. And, at car shows I run the 40's music out of the radio speaker all day and the neighbors and visitors love it.
I have since replaced the CD player with an MP3 player that is also an AM/FM stereo radio receiver.
Just an idea.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 11-07-2013, 07:52 PM   #6
wisbangman
wisbangman's Avatar
Jon............ See my post under your " 1939 ford glove box " post. I used a Sony 12 volt radio that I bought at Best Buy, it seems like I paid about $70.00 for it. The two speakers I used were Walmart, maybe $40.00. One of my friends said, " You better mount the speakers where you can build a nice fancy enclosure for them to get the best possible sound " I DID NOT TAKE HIS ADVICE. and instead, with no enclosure, the new speakers, instead of New Car Sound, remind me of how radios sounded in cars 70 years ago which was just what I was looking for ! The radio comes with a remote but the glove box door needs to be open to work with the remote, as it is a " line of sight radio / remote. " Again I went 12 volt, with a marine battery in the trunk, hidden in a vintage picnic basket. Every time I open the Picnic basket I hear " That's really unique " If the battery was sitting in the trunk, naked, in front of God and everyone else ! maybe I would get a different response.
wisbangman is offline   Reply With Quote
