I've been thinking (Whoa, is something burning?) Bearing in Mind, Bernouli's princible of a venturi (The more choked down, the faster the air goes) Can we increase the air flow into a carb. by placing a tapered horn at the intake? And how long and how much taper is required? What would be the optimum size of the mouth?
Terry |
Yes, you can. Aren't they called velocity stacks?
The way I understand the principle of a venturi is that the gas passing throught it slows down and its pressure increases....
Oops sorry should have typed pressure decreases and the gas flow increases..
#5 | |
![]() Quote:
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho (although still a Montana hillbilly at heart ![]() 1931 Coupe 1931 slant window sedan |
When you increase the speed of air through a venturi, you only increase the speed of the air through the venturi itself, and the pressure increases, assuming the pressure (or vacuum) on one side of the venturi remains constant. However, in the case of your Model A carburetor, you have a vacuum on the motor side of the carburetor (the intake manifold) and a venturi is already used in the carburetor to assist with ionizing the fuel as it meets air and mixes in the carb just beyond the jets. If you add an external venturi to the atmosphere side of the carburetor, you will increase the vacuum on the manifold side of the carburetor which will reduce the engine's ability to draw in air/fuel mixture and will reduce horsepower. If you had a turbo or blower to increase air pressure on the atmosphere side of the carb, you could certainly play with a venturi to tune the system. |
#7 | |
I guess my question would be, if there was a venturi at the mouth/intake of the carb., would it increase the amount of air entering the mouth of the carb?
Terry Quote:
The velocity stack (if that's what it's called) is used, it isn't a venturi, but a trumpet shaped inlet pipe to smooth the flow of air entering the carb. You'd have to do a dyno test to see how much help it gives.
#9 | |
![]() Quote:
I see only a few ways to increase the volume of air entering the engine. Increase the vacuum the pistons create when the "suck" in air fuel mixture, push the air in with a blower of some kind remove restrictions in the path on the way to the cylinders. Some will make greater horsepower, some not.
Aaron is right. There needs to a camber to the venturi which causes the pressure change. Look at an airplane wing or propellor. The air passing over the camber increases its speed which decreases the pressure allowing atmospheric pressure on the fuel in the bowl to overcome the lower pressure and fuel is then introduced into the venturi area.
#11 | |
![]() Quote:
http://en.wikipedia.org/wiki/Velocity_stack |
add a tornado
#13 |
FYI- I meant "atomize" but for some dumb reason, typed "ionize". Sorry for the error. Thanks, Skip!
#14 | |
Yes, Tom. Very much like that. Longer and more tapered, not bell mouthed. I was thinking of increasing the velocity at the mouth of the carb and then the carb's venturi would increase it some more. That was the idea anyway. Give the air velocity a boost, get it up to speed before it enters the carb. It seems like it would increase the amount of air entering the carb. I'm sure I'm n ot the first one to think of it. Pretty elementary, yet I've never read of it.
Terry Quote:
#15 |
Just mount a BIG, BIG, funnel on the front of the car & duct it to the carb with a flexible hose! Now, wasn't that EASY?? (OH! & paint the inside of the funnel, RED!!)
Bill W.
#16 |
The short answer is: it would increase the velocity, but decrease the flow - as above. The venturi is a restriction, so you would end up with slightly less air travelling at a faster rate, through a smaller hole.
The bell mouth (velocity stack) increases flow, and removes the turbulence at the mouth of the carb - the bell allows for smoother transition of the air in the carb mouth, as shown in the wiki article mentioned above.
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" |
#17 |
How about a crank driven blower??
Paul in CT |
#18 |
Yes, venturi is a restriction...the restriction serves to provide the motivation for the gas to flow in. Like the airplane's wing shape providing lift...that is a drag on the airplane, but again a useful one, since lift is REAL handy in airplanes.
This is a point of superiority for fuel injection, which provides the motivation for the gas to move by a pump that doesn't influence flow. From what I have read, though, the pressure drop of the venturi helps with atomization and so is perhaps an advantage in another way. |
#19 |
turn the carb around so the fan can blow the air into the throat..
#20 |
Let me go out on a limb here and make a few statements: Bernoulli's Equation is actually a mass and energy balance around the venturi. Since the mass rate of air flow in must equal the mass rate of air out, simply pounds in equalls pounds out thus nothing is lost, then any other changes of energy such as velocity must be balanced with a an appropriate change in another energy such as pressure energy.
When the air enters into the large area venturi at a given flow rate, it must speed up in the smaller area of the venturi and thus the velocity energy of the air increases with respect to the velocity energy at the entrance to the venturi. When this increase in velocity energy happens, it must be balanced by a corresponding decrease in another energy of the fluid, in this case the pressure energy of the fluid to maintain an energy balance. Since air entering is, let's say 14.7 psi absolute at sea level, then the pressure of the fluid in the narrow part of the venturi must be less than 14.7 psia. due to the increase in velocity. If the gas in the float bowl is at 14.7 psia, same as the entering air pressure, then it will flow from the jet located at the narrow part of the venturi into the airstream. Changes in the airstream prior to the venturi will just disrupt the hopefully smooth flow into the venturi throat thus reducing the effectiveness of the venturi. This same thought pattern shows why the Model A carburetor will force the fuel air ratio to become more rich when an air filter is used. Hope this helps rather than confuses..... John Cannon |
