Old 08-25-2013, 08:17 AM   #1
Tom Cavallaro
Tom Cavallaro's Avatar
Default Pop out key switch
Can the original popout switch be rebuilt..repaired? If not is there a reliable replace part or parts? I check my electrical system and have 6 volts everywhere except at the points arm when the key is on.
I work very hard to avoid all and any mistakes. I thought I made a mistake once, but I was wrong.
Tom Cavallaro is offline   Reply With Quote
Old 08-25-2013, 08:47 AM   #2
Steve Plucker
Default Re: Pop out key switch
Here you go...
POPOUT (IGNITION) SWITCH
1. No known website: Dick Crabtree 605-487-7229
Pluck
Old 08-25-2013, 10:11 AM   #3
H. L. Chauvin
Hi Tom,
Mr. Crabtree can do a good job of restoration -- he did my original pop-out switch a few weeks ago -- very well pleased.
H. L. Chauvin is offline   Reply With Quote
Old 08-25-2013, 10:30 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
Some things to check before condemming the popout---
If the points are closed you won't have 6V, or if there is a problem with the insulation with the lower to upper plate wire, and sometimes if the popout end is screwed too tight into the dist housing it pushes the lower plate contact against the dist housing shorting it to ground
Old 08-25-2013, 11:26 AM   #5
John LaVoy
John LaVoy's Avatar
If you use Mr. Crabtree please let me know how it turned out. We are always looking for quality vendors to review.
John LaVoy is offline   Reply With Quote
Old 08-25-2013, 12:46 PM   #6
machineman64
Hi there,
I had Dick Crabtree rebuild a pop out switch for me.
Very satisfied, quick turnaround, good communications,
reasonably priced, and a professional job.
John
machineman64 is offline   Reply With Quote
Old 08-25-2013, 06:50 PM   #7
Fred
He has done 15-20 for me with no problems, including the early ones..
Fred is offline   Reply With Quote
Old 08-25-2013, 08:58 PM   #8
Pinstripe
Dick C. did 2 for me- very satisfied.
Pinstripe is offline   Reply With Quote
Old 08-25-2013, 10:29 PM   #9
Bob from Northport
Bob from Northport's Avatar
Dick has done several switches for my little garage, and they are all great!! Just received another for a 30' sport coupe. Thanks Dick!!
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 08-26-2013, 09:46 AM   #10
dr.j
No question, Dick Crabtree is the expert and a fair honest one at that.
Dave A Jamieson
Portland, ON
Canada
1928 Tudor
dr.j is offline   Reply With Quote
Old 08-28-2013, 05:58 PM   #11
Tom Cavallaro
Thanks for the info. I've been working 13 hour days and have not been able to get out to the car again until today.
What am I looking at? I checked for a short between ground and the points, and no continuity. I put the positive on the battery and turned the key on opened the points ...no spark...put cardboard between the points and no 6 volts, and checking at the coil the way it is on the firewall, the right side shows 6volts and the left is showing 1 volt. What am I missing? Thanks in advance...I'm real tired.
