Old 08-09-2013, 09:40 AM   #1
chuck stevens
chuck stevens's Avatar
Default Re: To Stat or Not To Stat? That is the question.
Maybe I'm being a little rude, but who just had engine trouble? I'll run 190's!
chuck stevens is offline   Reply With Quote
Old 08-09-2013, 09:51 AM   #2
38 Ford Guy
38 Ford Guy's Avatar
One thing I have learned about Flatheads....each one runs different temps. I have a three of them built the same and one always runs warmer. I have tried a several combinations and it always sits around the 220 to 230 area. Without stats 160 to 180 I have found stats make it worse so for me doing what Henry did is well worth the try it is only $15.00 (with shipping) and a little time. For 15 bucks I will hold off buying a case of beer and a headache the next morning.
"If you always do what you have always done then you will always get what you always got."
Henry Ford
38 Ford Guy is offline   Reply With Quote
Old 08-09-2013, 09:55 AM   #3
Old Henry
Old Henry's Avatar
Not that it had anything to do with the trouble I had but that engine trouble was without thermostats. I noticed that every time the engine got down toward 130° or below it did not run as well as above that. All the more reason to run stats.
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 08-10-2013, 07:26 PM   #4
flatjack9
flatjack9's Avatar
Your engine problem could have very well been in part caused by no thermostats and widely varied engine temperatures.
