Old 08-01-2013, 07:21 AM   #1
BobbyG
BobbyG's Avatar
Default Stupid question re rear spring
Guys - On my coupe - the area inside the trunk on the floor directly above the rear crossmember that the rear spring sits in - I have a metal panel that is fixed flush with the trunk floor.
Now - Todays job is re fitting the rear end & spring BUT I also want to fit new U bolts
Am I right in thinking that the panel directly above them that appears to be 'stuck' in place with seam sealer HAS to be removed in order to get the old U bolts out and new ones in ?
Bob
BobbyG is offline   Reply With Quote
Old 08-01-2013, 07:23 AM   #2
RonC
RonC's Avatar
Default Re: Stupid question re rear spring
What's wrong with the old U-Bolts? Are they damaged?
RonC is offline   Reply With Quote
Old 08-01-2013, 08:10 AM   #3
BobbyG
BobbyG's Avatar
Looks like thread is damaged - nut flew off at me
Old 08-01-2013, 11:00 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
The center bolt may be rusted in two, and that would leave a lot of pressure on the 2 u-bolts. I assume you were in the process of removing the rear end?
If possible I would reuse the u-bolts and nuts. The last few threads on the u-bolts could be cleaned up with a threading file.
Old 08-01-2013, 11:15 AM   #5
Rowdy
Proceed with caution if the nut flew off at you. Like Tom said it is likely the center bolt is broken. Take a couple of large C-clamps and try to clamp as much of the rear springs back together. Then see if you can take a punch and drive out what is left of the bolt. If you get it all out try to put a piece of allthread through the springs and a nut on ontop to help hold it all together. Rear springs are dangerous to work on. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 08-01-2013, 11:19 AM   #6
ctlikon0712
ctlikon0712's Avatar
Enough can't be said on proceeding with caution...... Do as Tom and Rowdy suggest.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 08-01-2013, 02:36 PM   #7
BobbyG
BobbyG's Avatar
Thanks guys.
