Old 06-27-2013, 09:07 AM   #17
whirnot
whirnot's Avatar
Default Re: Champion 3X plugs
Originally Posted by Joe K View Post
law of mechanical repair
once your hands become covered with grease,
your nose will itch and you'll have to pe
Mine seems to be - walk all the way out to the shop - get engaged in something - and immediately have to return to the house to go to the bathroom.
I have this path worn between the shop and the house...
And not a lot of progress.
Joe K
Bury a 5 gallon bucket with holes in it outside the shop, connect 2 inch pipe and route thru shop wall about waist high, with a cap on the inside.
Then what you do with said contraption is your business.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
