05-29-2013, 10:45 PM | #21 |
Re: 30 or 31 pheaton which is it
Here's a link to the post I did showing the body date stamp. This was on an indented firewall, but I don't recall the body style, other than it was a closed car.
https://www.fordbarn.com/forum/showth...date+wesenberg |
05-29-2013, 11:00 PM | #22 |
Here is firewall
05-30-2013, 12:49 AM | #23 | |
05-30-2013, 03:53 AM | #24 |
Sounds like you have a late 30 - early 31 then. Unfortunately, that's probably as close of a guess as you will ever get to make. I would make it a 31. Rarest of the standard phaetons plus if you ever needed to, the front fenders and running boards are so much easier to change on a 31.
DMAFC |
05-30-2013, 08:05 AM | #25 |
ok I think I misunderstood what I read the front door has 2 bolt rear has 3 bolt so it is a 30
05-30-2013, 10:49 AM | #26 |
05-30-2013, 05:17 PM | #27 | |
Thanks for the reminder about the Ontario Plant production of Canadian Bodies, this probably explains why the Canadian Phaeton Body Number stamps are located in the "Wrong" area. Darryl in Fairbanks 85 degrees today Tom Wesenberg, you must have the weather we had about 10 days ago, snow, sleet, rain, and 25 degrees, summer started about 5 days ago here. |
05-30-2013, 10:47 PM | #28 |
Here are apic
05-30-2013, 10:51 PM | #29 |
Another pic it's only letting me load 1
05-30-2013, 11:04 PM | #30 |
Not standing by my car now but I think it's long hinge on bottom. There's also a left and right hinge. Look for a capital L or R on each hinge.
DMAFC |
06-01-2013, 08:31 AM | #31 |
Thanks everybody for the help doors are hung
