Re: Gas Tank Restoration - Tank RENU
Tank RENU makes the holes on the outer part of the tank on the bottom (at least that is what they did on mine). That way, the holes are where the tank can be cleaned from the baffle outward - both sides (two holes). You can see where the hole was made on my tank, but it is on the bottom where it is not visible unless you really get under the tank and look for it. The middle part can be done through the filler. This seems like a good way to do it - not very intrusive. I wish Eric Johnson's Tank RENU could have done my tank instead of the Minneapolis outfit.
Rusty Nelson
