Old 05-14-2013, 10:06 PM   #1
keith oh
keith oh's Avatar
Default Re: Good photo of Skip's impeller?
I don't understand what you folks are talking about when you say spiral impellers Skip uses. I sent my 35 pumps to Skip a couple of years ago and the only change in the impellers was a little longer vanes, that I could see. I am not complaining, as they work well,just curious.
keith oh is offline   Reply With Quote
Old 05-14-2013, 11:49 PM   #2
Old Henry
Old Henry's Avatar
If you look at his web ad, the turbine impellers are only for 37-48. The 32-36 just get the "new improved high volume impeller": http://www.fordcollector.com/water_pumps.htm
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
