04-29-2013, 10:18 AM | #21 |
Re: Aluminum One-Piece Fan. Issue...Maybe...
Will a picture of my 1928 work?
04-29-2013, 10:54 AM | #22 |
Yes it will work enough for me to know mine is nothing like it. I have the radiator out so I'll take a picture when I go home for lunch.
Jamie Crosson 1929 Tudor Looking for an Original 888 Key |
04-29-2013, 07:41 PM | #23 |
Wouldn't a sagged chassis also cause the fan to be closer to the pipe. If the rear of the engine drops, the upper forward will move back slightly from the rotation of the engine along its length. Just something else to think about.
04-30-2013, 01:53 PM | #24 |
Well I attached some pics.
The first three are the original steel fan. The baby's cut down to 13 1/4"...didn't even realize it. The one of the hub shows the crack forming. The last one shows the clearance between the inlet neck of the radiator and the fan AFTER shimming. That's about the best I'm going to get. Thanks for all the interest in the subject and the tips...I'll let you know after I refill the radiator. Waiting on a lower steel pipe for the engine inlet...Mine looked like Swiss cheese; the paint was literally holding the coolant in. Steve |
04-30-2013, 02:14 PM | #25 |
Hey Smurkey! Any chance your engine is too high? Will the hand crank fit in the crank nut?
04-30-2013, 08:02 PM | #26 |
04-30-2013, 09:44 PM | #27 |
Steve,
Good advice above from Tom on the Water necks..... sounds like the radiator neck may be on of the issues. Take a line of sight from the side with the hose off, making sure you have the correct height ( not sure if it's 28/9 or 30/31 you are working with ( despite 29 photo in avatar) but I would lean toward fixing the radiator and core problem.... I would not put a cracked fan back on no matter how long you might feel it's been there. Should be heliarc welded properly if repaired for re-install. Good luck! Larry Shepard |
05-06-2013, 04:46 PM | #28 |
Hey, just a follow up. The gap was/is sufficient. Just went for a 20 mile cruise (first on of the season) and all worked well. Now with some peace of mind about the fan.
Happy with the thermostat I installed too! Steve PS the stainless lower coolant pipe from Brattons is a beaut. Thick gauge, looks right, almost a shame to paint it black. Well worth the extra 3-4 bucks!! |
05-06-2013, 04:52 PM | #29 |
use the 6 blade plastic, want to show your car put on an org, 2 blade alum is still a fake
05-06-2013, 05:18 PM | #30 |
Tests have confirmed that a 6 blade fan is actually less beneficial than an original style at speeds greater than 20 mph. The reason is the 6 blade fan creates a curtain wall of air which does not allow additional air to flow across the fins. A 2 blade fan will keep all but a fully loaded AA truck cool at speeds under 20 mph. Over that, you don't even need a fan to cool the engine.
05-06-2013, 07:23 PM | #31 |
out of curiosity, does anyone know if the '32 etc. Ford fans were of the same design?
