Old 02-04-2013, 09:36 PM   #1
BERNIE G
BERNIE G's Avatar
Default 60hp rod bearings
New kid on the block, lookin for some help. I need .040 Rod Bearings for my 37 - 39 Baby Flatty. Any pointers would be apreciated.
BERNIE G is offline   Reply With Quote
Old 02-04-2013, 10:53 PM   #2
f1builder
Default Re: 60hp rod bearings
for some reason 40's are very hard to find in all size flatheads. you might want to look for another crank. maybe egge's tech's can help you.
f1builder is offline   Reply With Quote
Old 02-05-2013, 08:19 AM   #3
BERNIE G
BERNIE G's Avatar
Thanks for the input and advice. I have been watching E-Bay with no success. Seems like every size but. I found most everything needed for my project, except Rod bearings. Have you ever heard of anyone turning a 1940 crank to 38 specs? Thanks again.
Old 02-05-2013, 09:08 AM   #4
KiWinUS
KiWinUS's Avatar
check getting crank welded back to stock as standard bearing are a lot cheaper & easier to find
Old 02-05-2013, 09:43 AM   #5
BERNIE G
BERNIE G's Avatar
Thanks, I was wondering if that is possible. Question is where,(who does that)?
Old 02-05-2013, 09:53 AM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Bernie, I've had alot of cranks welded up and ground back to std. They were usually industrial engines. It's pretty expensive, I know .040 bearings are real hard to find. I would still keep looking for a carnk that would grind to 10-20 Put a post on the Sell Swap site here on the barn ( wanted 37-38-39 60hp crank that will grind to .010 or .020 ) i'll make a couple of calls and try to locate one. Walt
Old 02-05-2013, 10:25 AM   #7
deuce_roadster
deuce_roadster's Avatar
My understanding is that back in the day when they were racing the little 60s everyone wanted the 1940 engine because it had larger journals and were marginally better for that purpose. Hence, they got used up and are harder to find now. Like Walt suggests, if you use the earlier crank, you might have better luck.
Old 02-05-2013, 05:31 PM   #8
BERNIE G
BERNIE G's Avatar
Thanks Walt, I think your way of thinking is right. Thanks Deuce also, all input helps. I'm not known for patience when I decide to tackle a project. Might not be too late to change. I am really not in any hurry. I do wear a hat that says, GIT-ER DONE..... Thanks again
Old 02-05-2013, 05:58 PM   #9
Gary in La.
Gary in La.'s Avatar
Call John Saturno in NY at (845) 294-6958. He has a large stock of V8-60 parts. .040" bearings are real hard to find but he might have them. Tell him Gary in Louisiana told you to call him.
Gary in La. is offline   Reply With Quote
Old 02-05-2013, 06:01 PM   #10
BERNIE G
BERNIE G's Avatar
Thanks for the lead. NY is a good road trip..
Old 02-05-2013, 06:55 PM   #11
Henry/Kokomo
Henry/Kokomo's Avatar
Hey, Bernie. Welcome aboard! If New York is a "good road trip", where's home for you? Maybe put it in your Avatar? Maybe?
Henry
Henry/Kokomo is offline   Reply With Quote
Old 02-06-2013, 08:26 AM   #12
BERNIE G
BERNIE G's Avatar
Thanks for the welcome. Home is in Southern Maine.
NY has 2 cranks available, and is checking to see what dimensions they are. Bernie.
Old 02-06-2013, 08:37 AM   #13
BERNIE G
BERNIE G's Avatar
Walt, The NY connection said he has a crank, sleves, and valve seats. Neither he nor I know how thick the standard sleve wall would be.(non-thin wall) Any ideas?
Old 02-06-2013, 09:09 AM   #14
KiWinUS
KiWinUS's Avatar
Frank Ezold in Conneticut also has alot of 60 parts ( I sold him a bunch including sleeves & he had lots) Ezolds old ford
Cheers
Tony
Old 02-06-2013, 09:11 AM   #15
Kurt in NJ
Kurt in NJ's Avatar
I too have a crank that was cut to .040,(was told--they're listed in the book, shouldn't be a problem) but it has been a long time, don't remember if bearings were found--and don't remember if it was the 37-39, or the 40 type, and there is also possibly a nos crank, I just moved the crankshaft collection(50+ cranks) but havn't sorted them.
From a Ford reconditioning book I can give the bore size for sleeves--the pre-finished tin sleeves--the bore in the block for the sleeve-2.6809-2.6812---which would put the sleeve thickness at about .040, for aftermarket and thick sleeves you should measure them, there is some mention in the book of .060, and .090 thick sleeves, but that could be for the larger engines ---aftermarket sleeves are chosen by size needed and have many sizes, and there are oversize original steel pistons.
Old 02-06-2013, 11:12 AM   #16
Rowdy
If you can find the old Federal Mogul and Mamouth numbers I may have them. I still have not sorted all of the NORS bearings. I have about 150 boxes of them to sort when I get to them. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-06-2013, 02:50 PM   #17
BERNIE G
BERNIE G's Avatar
Thank you all for such great feedback and leads...
So many possibilities are very encouraging, and hopeful.
Likely i'm not the first person to become so passionate (for lack of a better word) about a project, that I dove right in without researching the parts supply first. Or the costs associated. And at just how deep in, do you not turn back, and seek an alternate route? I guess my friend has summed it up.." It's NOT A MATTER OF NEEED".
Thanks Bernie
Old 02-06-2013, 08:30 PM   #18
Walt Dupont--Me.
The only sleeves that I have seen for the 60 were .040 I know they made .090 for the big engine and probably did for the 60. The unaversal sleeves were usually 3/32 and 1/8 Walt
Old 02-07-2013, 10:31 AM   #19
BERNIE G
BERNIE G's Avatar
Kurt
If you have an nos crank for a 37-39 60hp, what would it cost, shipped to maine? Thanks Bernie
Old 02-07-2013, 07:49 PM   #20
russcc
Couple of ideas: Call Lisa at Then & Now Automotive in Weymouth MA, or Fred Wilner at South Side Obsolete in Faribault MN. They both have vast stores of NOS & NORS stock. The NOS operation of Dennis Carpenter is also a good source to try. Call the regular nuber and ask for the guy in NOS.
