Old 01-21-2013, 08:18 PM   #1
wrndln
Default Phaeton top prop knob question
I have a question about how the top prop knob stays on the top iron pivot stud. I am attaching a picture of the stud and knob. The concern I have is that the top irons need to pivot, so the knob can't be tight or it would be hard to move the top irons up and down. If the knob is not tight, it seems like it could loosen and fall off. Would some Fordbarner(s) that have a finished phaeton please explain how the knob is held in place without falling off and still allow the top irons to move easily.
Rusty Nelson
Old 01-21-2013, 08:24 PM   #2
pat in Santa Cruz
pat in Santa Cruz's Avatar
Default Re: Phaeton top prop knob question
there is a metal clip set behind the knob that locks it in place with a bent tab. You'll find it in any suppliers inventory
pat in Santa Cruz is offline   Reply With Quote
Old 01-21-2013, 08:25 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
The knob is tight against the folding top iron. My knobs have never come loose.
Old 01-21-2013, 08:26 PM   #4
Tom Wesenberg
Wasn't that only on 30-1 or delux?
Old 01-21-2013, 08:41 PM   #5
d.j. moordigian
d.j. moordigian's Avatar
Originally Posted by Tom Wesenberg View Post
The knob is tight, but not tight against the folding top iron, which pivots on the smooth portion. My knobs have never come loose.
Tom, are you saying that it bottoms out on the thread?
d.j. moordigian is offline   Reply With Quote
Old 01-21-2013, 08:57 PM   #6
Tom Wesenberg
The knob fits against the folding top iron, which fits up to the larger diameter smooth part of the shaft.
I would like to hear from someone about the locking tabs, but I thought I was told a few years ago they weren't used in 28-9.
Old 01-21-2013, 09:44 PM   #7
Marco Tahtaras
Marco Tahtaras's Avatar
The only place those locking clips were ever used was on Cabriolet landau irons (all years). Ford's engineering department specified them for the Deluxe Roadster and rescinded that less than a week later, before it even went into production.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 01-21-2013, 09:58 PM   #8
Tom Wesenberg
Correction.........I just looked at my 1928 Phaeton knobs and they DO tighten against the top iron, which butts up to the large smooth part of the shaft. I was going to loosen one to see how tight it is, but I need a thin wrench to fit the square part of the knob.
Old 01-21-2013, 10:13 PM   #9
Great Lakes Greg
Great Lakes Greg's Avatar
I have the clips on my phaeton. They are hardly noticable and give me piece of mind. Seems like a top iron scraping down the side of the car at speed would be pretty ugly.
Great Lakes Greg is offline   Reply With Quote
Old 01-21-2013, 10:28 PM   #10
Phil
Phil's Avatar
I also have the thin sheetmetal clips on my 28. Never had any problem with the prop coming loose.
Phil is offline   Reply With Quote
Old 01-21-2013, 10:41 PM   #11
Marco Tahtaras
Anyone ever hear if the cars coming with a tool kit under the seat which included simple open end wrenches for such tasks?
Old 01-22-2013, 10:40 AM   #12
d.j. moordigian
Thanks Tom,...that's a load off my mind.....I was worried! I'm sure Rusty
and I feel better...
Old 01-22-2013, 10:48 AM   #13
wrndln
I still don't know what keeps the top prop from loosing and falling off if the sheetmetal clip isn't used. If the top props was tightened tight against the top iron eyelets, it would seem it would be hard to move the top up and down. I know a little blue Locktite would do it, but I am sure Ford didn't use something like Locktite.
Rusty Nelson
Old 01-22-2013, 02:41 PM   #14
Arlen
Arlen's Avatar
I tighten my knobs all the way tight when driving. When I want to put the top down, I turn them loose a half turn or so. I just make a point of checking them every so often to see that they are still tight but its never a problem. I tighten them as tight as they go and it's never a problem.
DMAFC
Arlen is offline   Reply With Quote
Old 01-22-2013, 02:57 PM   #15
Dick Carne
Dick Carne's Avatar
We tightened the knobs down on our '29 touring car when the car was first restored back in the late sixty's - the car underwent a cosmetic re-restoration in 1990, but the knobs were not removed (the top is still on from the sixty's restoration), and we've never encounted any problems with loose knobs or excessive resistance to raising and lowering the top. For what its worth, we don't have the "locking tabs or clips" either. Hope this helps.
Dick
Dick Carne is offline   Reply With Quote
Old 01-22-2013, 08:40 PM   #16
peters180a/170b
peters180a/170b's Avatar
So what you are saying Marco , the folding tabs do not belong on the Deluxe Phaetons???
peters180a/170b is offline   Reply With Quote
Old 01-23-2013, 04:17 PM   #17
Marco Tahtaras
I knew that would wake you up! Yes, the same clip was used on the 180-A. For those not already familiar, the 180-A also used the same knobs as the Cabriolets. All other models used smaller knobs.
Old 01-23-2013, 09:42 PM   #18
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
How do you remember all this stuff, Marco?? Bet your DOG helps you!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-24-2013, 01:27 PM   #19
swo4rd
swo4rd's Avatar
The
only place those
Marco, I think you confused us in the quote above: "The only place" or was that a trick answer? D Incidentally, I will be looking for some of those knobs soon...
swo4rd is offline   Reply With Quote
Old 01-24-2013, 03:42 PM   #20
FL&WVMIKE
FL&WVMIKE's Avatar
I'm not in competition, so I like those locking tabs on my '29 roadster.
MIKE
FL&WVMIKE is offline   Reply With Quote
