12-08-2012, 02:10 PM | #1 |
interior door panels, upholster
WHERE; can I get interior door panels, fiberboard precut with holes,( window crank/door handle ) I have inquires in Le Baron Bonney and Cartouche, is there someone else ?? My 39 fordor came to me all apart, like body off, doors off, glass out, most all there, but all apart. I have one door panel, driver ?? thanks for all you help, through the years .......... OLD....BILL
12-08-2012, 02:26 PM | #2 |
Re: interior door panels, upholster
I believe Macs has a complete kit you can buy for all panels, etc. I bought the board and cut my own before I found out Macs sells them. Still turned out good.
Mike |
12-08-2012, 02:27 PM | #3 |
With one sample you can make a set. Buy the proper panel material and make the holes. All said and done buy the panels cut to size and pre punched.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. |
12-08-2012, 02:30 PM | #4 |
LeBaron Bonney has the panels and will sell them as a set separate from their upholstery kits.
12-08-2012, 03:46 PM | #5 |
Restoration Supplies in PA carries the panel board in sheets and other similar stuff. Their web site is: www.restorationspecialties.com
Good luck! Bruce
Failure is simply the opportunity to begin again, this time more intelligently.......Henry Ford |
12-09-2012, 10:05 AM | #6 |
12-09-2012, 11:18 AM | #7 |
There is a U-tube video of LeBarron Bonney using their computerized cutting machine to "cut" some panels for a 49 Ford (if I remember correctly). The machine has special cutting tooling to cut any size or shape that is cad cam fed into it. It's a pretty amazing machine. Wished I could afford one.
