Old 11-17-2012, 11:20 AM   #3
John Stone
John Stone's Avatar
Default Re: Is a lightened flywheel overrated? (I think so)
Brent, I agree with you 100%. I like the heavy flywheel until I have to lift one but that is only temporary.
One member of our club says the lightened flywheel is good because when hitting a railroad track, the crankshaft does not flex as bad and cause the center main to go out. (I say the crank is probably not ground on a center line)
Another one say he likes the V8 pressure plate because it is easier on the left leg. He is a machinist and actually turns the flywheels down.
John Stone is offline   Reply With Quote
