Old 10-12-2012, 12:47 PM   #1
aarestor
Default 35-36 Ford Parts
City: Rapid City
State: SD
35-36 Above Front window Header Panel
35-36 Wire wheels. $35.00 each.
35 headlight buckets. $25.00 each.
35 Ford fenders and inner fender panels
35-36 window trim garnish moulding, dashes, doors,fenders,window regulators, and much more.
aarestor is offline   Reply With Quote
Old 10-15-2012, 04:27 PM   #2
Steel A Rod
Default Re: 35-36 Ford Parts
Hi, is the car a hump back. If yes do you have the trunk area of the body?
Thank you
Steel A Rod is offline   Reply With Quote
Old 10-23-2012, 10:44 PM   #3
35tudor
Hi are the garnish moldings the ones that mount under the window frames? Thanks, Kevin
35tudor is offline   Reply With Quote
Old 10-24-2012, 01:32 AM   #4
Boston st.35
Hi, Hopeing to fine a regulator for the windshield for a 35
Boston st.35 is offline   Reply With Quote
