Old 10-10-2012, 01:03 PM   #1
coolcoupe
coolcoupe's Avatar
Default temp gauge
My temp gauge goes from cold to hot (pinned) but takes about 5 minutes,the engine is not that hot.What could cause this?
coolcoupe is offline   Reply With Quote
Old 10-10-2012, 01:31 PM   #2
41ford1
41ford1's Avatar
Default Re: temp gauge
Check this thread: https://www.fordbarn.com/forum/showthread.php?t=85681
If you are using both the 2 terminal and 1 terminal sensors try bypassing the 2 terminal. The 2 terminal is basically an over temp switch. The 1 terminal unit measures temperature.
41ford1 is offline   Reply With Quote
Old 10-10-2012, 01:40 PM   #3
Old Henry
Old Henry's Avatar
If it still does the same after bypassing the left two terminal sender as 41ford1 suggested it's most likely a defective single terminal sender on the right side. Replacements available here: https://secure435.hostgator.com/~dlv...g=130&t=885&tn=
Prof. Henry (The Roaming Gnome)
"It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness
Old Henry is offline   Reply With Quote
Old 10-10-2012, 05:48 PM   #4
coolcoupe
coolcoupe's Avatar
Thanks Guys I will try that.
