Another way to tell them apart at a glance is to check the flange where the bracket bolts to the frame:
On the 1928-29's the flange is much thicker at the lower bolt hole than it is for the 2 upper bolts. As well, the lower uses a 1/2" bolt while the 2 upper ones are 3/8". The 1930 brackets have the thinner flange uniform for all 3 holes and use all 3/8" bolts to attach. |
