Old 08-10-2012, 11:32 PM   #6
columbiA
Default Re: Hood alignment & adjustment
Looks like the rear hood hinge bracket has to be mved to the left.Loosen the rear screws & the caged nuts will allow the bracket to be moved a bit.You can also add a shim or two under the bracket to raise it if gap is wider at bottom.
columbiA is offline   Reply With Quote
