Old 06-12-2012, 06:39 AM   #11
George Miller
George Miller's Avatar
Default Re: Float a motor
Yes, yes, yes
The drive shaft is fasten to the engine with a solid torque. Which keeps the rear axle from moving forward or back. When you hit a bump with one of the tires it tries to move the end of the torque tube in a ark. the transmission and engine have to hold it. The later cars from Ford had the torque tube and transmission connected to frame cross member.
Modern cars use a open drive with a different axle mount. It is different animal altogether.
George Miller is offline   Reply With Quote
