Old 05-24-2012, 09:21 PM   #1
CWPASADENA
CWPASADENA's Avatar
Thumbs up Re: Clutch disc with spring center
Originally Posted by columbiA View Post
The compression springs in the hub & the wafer springs behind the clutch facings make for a smoother engaging clutch.I always throw away the old style solid centre discs no mater how good they look.
I AGREE!!!!!!!
I have been using the later style clutch discs for more then 50 years. They work much better then the old style solid discs.
CW
CWPASADENA is offline   Reply With Quote
Old 05-24-2012, 09:37 PM   #2
ScottNW/Ohio
ScottNW/Ohio's Avatar
Default Re: Clutch disc with spring center
"Solid" clutch discs are usually cheaper, but you will "pay" in the end with things like chatter when engaging, vibration, and extra wear on the input shaft.
Buy the spring loaded disc.
ScottNW/Ohio is offline   Reply With Quote
