Banned
I've been hearing this term on Model T's. The term is "Babbit." What is a Babbit? What does it do and what does it look like?
Babbit is the metal that is poured on the rods and mains to make the bearing surface.
Banned
So it's a liquid metal?
http://www.amosauto.com/Articles/Cla...bbitt-bearings This site gives some good information & good pictures of the process. Simply put, modern engines have replaceable thin bearing shells with a babbitt surface already on the inside. Model Ts & others have the babbitt melted & poured in the block & rods, then after cooling it is machined to fit the crank shaft. |
