Old 04-13-2012, 01:27 PM   #8
Greg way out West
Exclamation Re: Another Cast Iron Brake Question
Hey Bill,
Forgot to add,,When turning the rear "New Drum's" you might want to check the E brake area of the drum...If using new Emergency brake linning,I think it's too thick...I cut the drum to true it up & make the E- linning not drag..How much,,You have to check to see how the drum goes over the E-linning..You might be Ok...
Greg,
Greg way out West is offline   Reply With Quote
