Old 03-21-2012, 07:20 PM   #1
Aok
Aok's Avatar
Default Compression Tester adapter size ?
I would like to do a compression test but need a adapter to fit my tester. I know the vendors sell one but do not need anything right now and would like to do this in the next day or so as I am in the process of doing a tune.
Anyone know what size bushing I need to fit the model a spark plug hole.
Aok is offline   Reply With Quote
Old 03-21-2012, 07:35 PM   #2
Colorado Greg
Colorado Greg's Avatar
Default Re: Compression Tester adapter size ?
Spark plug hole size is 7/8-18. You could also use an old plug, gut it and tap it to the size you need.
"Betsy doesn't leak oil - she just marks her spot"
Colorado Greg is offline   Reply With Quote
Old 03-21-2012, 07:54 PM   #3
glenn in camino
glenn in camino's Avatar
I replaced the small rubber sealer on the end of the compression guage with one I made out of a rubber bushing that I think came from a modern shock absorber. Works good.
Old 03-21-2012, 08:20 PM   #4
Aok
Aok's Avatar
Thanks 2 good suggestions I will see what I can come up with
Old 03-21-2012, 08:53 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I have used an old sparkplug and for the tester thread I use a "anti-fowler ---braze them together ----I guess JB weld or such would work too if there is enough surface glued but it wouldn't be as reliable as brazing or welding
Old 03-21-2012, 09:03 PM   #6
Popeye31
Popeye31's Avatar
My compression gadge has a quick disconect like a air hose I gutted a sparkpluge and welded a fiting that will go on my compression gadge works great.
Live your dreams
Popeye31 is offline   Reply With Quote
Old 03-21-2012, 10:48 PM   #7
fordfixer
If you can get your hands on the spark plug adaptor for modern 18 mm. plugs, the compression gauge should screw right into it. This is what I use.
fordfixer is offline   Reply With Quote
Old 03-21-2012, 11:32 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I have a cheap, old hand held tester, and it's rubber cone is plenty big for the 7/8" plug holes. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-21-2012, 11:34 PM   #9
ABento
I have checked at napa and have not found an adapter for the 18 MM plugs such as John Deere or International use, and I believe that the "A" plug is 7/8 x 18 not 18 MM, I asked here about an adapter and Branten sells them for 6.50
It seems I missed the post by Ford fixer, I was under the impression that the 7/8 x 18 was not in MM.
ABento is offline   Reply With Quote
Old 03-22-2012, 08:40 AM   #10
fordfixer
Sorry if I had the 18 mm part wrong. I was in a rush last night. The parts houses sold a adaptor for using the modern plugs. This is the one I meant for you to use. They also are good for making and engine lift bolt.
Old 03-22-2012, 10:04 AM   #11
Purdy Swoft
Purdy Swoft's Avatar
Lots of the model A parts houses sells a 7/8 x18 adapter for useing modern 14MM spark plugs in the model A. The adapter will need 7/8X18 threads to thread into the head. The threads on my compression tester is 14 MM. I use the modern spark plug adapter from Snyder with my compression tester. 7/8X18 to 14 MM
Old 03-22-2012, 10:46 AM   #12
1928Pickuppain
1928Pickuppain's Avatar
Take plug gut it and solder it to the end of yours that's how I did mine works pissa
1928Pickuppain is offline   Reply With Quote
Old 03-22-2012, 10:47 AM   #13
CarlG
CarlG's Avatar
What Purdy said!
I went ahead and bought a package of 4 to save a few bucks. I have one on my compression tester, put one on my leak down tester, and my fellow Model A'ers have snapped up the others.
Old 03-22-2012, 07:28 PM   #14
Aok
Aok's Avatar
I have solve my problem with a old tool I forgot I had, I was looking for a gauge with the rubber base like BILL WILLIAMSON had suggested in a earlier post when I found a old mechanical compression tester I picked up somewhere years ago. The reads were 50, 50, 45,50 which I think is ok.
I 1st used the base to connect to my new tester then used the old mechanical tester readings were about the same
