Old 03-10-2012, 08:11 PM   #1
elwood
elwood's Avatar
Default transmission help
Well I took this 3 speed top loader out of my 50 F1 and I scored this overdrive today, and Id sure like to put it in my F1.
Looks like its goanna a pain, not to mention its a side loader.
Any thoughts guys ?
thanks
elwood is offline   Reply With Quote
Old 03-10-2012, 08:28 PM   #2
Will Kimble
Default Re: transmission help
Well the good is that some F1s had side shift transmissions, so that part of the swap (column, linkage) should be pretty seamless. Bad is that it looks like the solenoid will land right about where the F1 crossmember lives.
Seems like Chassis Engineering has some engine/trans swap stuff for F1s, I bet there is a tubular trans crossmember that would be a good match for the rear mount on the overdrive. Good luck, looks like a cool idea to me!
Will Kimble
Will Kimble is offline   Reply With Quote
Old 03-10-2012, 09:18 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
Early 50 F1 pickups had the floor shift then they were all column shift. Shouldn't be too hard to find a column to change it over.i would defiantly make the swap if it were mine. You could fab a new xmember and probably have to shorten the driveshaft.
Old 03-11-2012, 12:16 AM   #4
elwood
elwood's Avatar
I kinda like the floor shift, im wondering if i can find a top loader case that the overdrive unit will bolt to ?
Old 03-11-2012, 03:16 AM   #5
expavr
expavr's Avatar
Its possible to keep the floor shift look by adapting a floor shift tower to operated a column shift trans or by using an aftermarket Hurst shifter. The attached photos show a 49 Merc sideshift O/D that I adapted to function as a floor shifter. I took an early Ford floor shift tower, removed the shifting forks and modified it with bypass brackets that work on modified trans shift linkage. the swap required machining and fabrication which wasn't cheap, but the original look was important to me. Check out the attached article from the HAMB regarding the use of an aftermarket shifter like Hurst to accomplish the same thing. http://www.jalopyjournal.com/forum/s...d.php?t=530470
expavr is offline   Reply With Quote
Old 03-11-2012, 10:17 AM   #6
rotorwrench
rotorwrench's Avatar
The (early)top loaders were never set up for overdrive so there are no (early type)top loader cases that will work with the Borg Warner electric overdrive the way it was engineered. The back of the case is completely different and the reverse lockout mechanism is part of the side shift cover assembly. The idea expavr has is the best one going. The electric shift solenoid can be placed below the transmission if you can find the rocker plate set up used on some convertible cars. I've see pictures of home fabricated set ups that mimic the rocker solenoid shifter in order to clear crossmembers and other frame members.
Old 03-11-2012, 11:01 AM   #7
38 coupe
38 coupe's Avatar
This has been discussed at length on the Ford Truck Enthusiasts forum in this thread. There are many options for overdrive that I cover in this post. My recommendation is to swap a 3.00 ratio 9 inch rear axle in and use a heavy three transmission since all of this can be done with no cutting of the frame.
rotorwrench, the T86 is a top loader and a lot of them have overdrive. A Jeep 3 speed shifter bolts right on. Check this out: http://www.google.com/imgres?imgurl=...t:429,r:27,s:0
Old 03-11-2012, 01:38 PM   #8
expavr
expavr's Avatar
My hat's off to whomever put together that list of Trans swaps identified in the FTE thread!!! Very impressive effort.
I'm not familiar with the later F series frames, but if they look anything like the 40 Tonner, the X member doesn't have to be modified. In fact its a simple mod to bolt an extension to the existing X member to catch the tailshaft support on the O/D trans. Here I'm assuming that the dimension from the front of the 50 trans/bellhousing to its rear support is the same as the early Ford large trucks. Your trans photos would seem to indicate that.
38 Coupe's suggestion of using a later 3.00 differential has merit. Couple that to a set of 30+ " diameter wheels and you'd get down the road at a good clip, although you'd lose the benefit of some low end torque if that's important. Google Engine RPM/Tire Size/Speed Calculator and it will show a range gear ratio, tire size options to consider.
Good luck with whatever you decide. Anything that makes these trucks more driveable is worth the effort.
Old 03-11-2012, 06:16 PM   #9
rotorwrench
[Quote from 38 Coupe]rotorwrench, the T86 is a top loader and a lot of them have overdrive.
You are correct but there were never any engineered to work on the flat heads as installed in pick ups of the F1 and early F100 era. The Borg Warner narrow rectangular bolt pattern will work with the 8BA/EAB family passenger car bell housing and clutch set ups. You just have to mach a clutch plate to the type of input spline. The late 51 Mercury cast iron bellhousing would work in an F1 with the later 4-bolt trans attach pattern as long as it's the narrow pattern. The clutch equalizer will bolt right up. Some of the T-86s with R-11 overdrive are not that easy to find nowdays. The old R-10s are still pretty easy to find.
It's a lot of work no matter how you do it. There are no just "Bolt In" set ups. Something always had to be modified. The solenoids still stick out the side just like the early set ups do.
Old 03-11-2012, 10:20 PM   #10
38 coupe
38 coupe's Avatar
rotorwrench - you are correct. I was not trying to be argumentative, I was just pointing out that there was a top loaded transmission that had overdrive.
In order to maintain the low end grunt with a 3.00 rear axle you can install a heavy three transmission. These have a much wider gap first to second and second to third. The 3.71 first gear ratio of the heavy three combined with the 3.00 axle ratio restores first gear to where it is with a light three and the 3.92 rear axle.
Old 12-08-2014, 02:14 PM   #11
Ol' Ron
Ol' Ron's Avatar
Yes, this is quite an engineering feat, which is what I love about this hobby. There are allot of thinkers out there. Did I spell that right??
Old 12-09-2014, 08:28 AM   #12
Cecil/WV
Cecil/WV's Avatar
Yes, t h a t would be the correct spelling for that! LOL
Cecil/WV is offline   Reply With Quote
Old 12-15-2014, 12:44 PM   #13
tanner
tanner's Avatar
I am interested in the swap from light duty 3 speed to heavy duty 3 speed as I have changed out the stock rear end to a 3:00 for better highway driving. The downside is getting started in low requires a little more clutch work. My 49 F1 is now turning 2000 rpm at 60 mph. I love the new setup but would like to try the heavy duty 3 if it is a bolt-in.
tanner is offline   Reply With Quote
