Old 03-07-2012, 06:42 PM   #1
Dusty
Dusty's Avatar
Default Reinforcing Bands
Will Reinforcing Bands for the drums help with brake fade?
dusty
Dusty is offline   Reply With Quote
Old 03-07-2012, 06:49 PM   #2
VWJoe
VWJoe's Avatar
Default Re: Reinforcing Bands
dusty
YEP,,,,
Joe
VWJoe is offline   Reply With Quote
Old 03-07-2012, 06:59 PM   #3
Keith True
Keith True's Avatar
Yes they will.New cast is the way to go,but if money is limited and your drums are not real bad they will do a good job.I've put lots of them on,not one person had a complaint.Of course,every one of them had waited until they had to throw out an anchor to slow down.I put a lot of them on at a place I worked at in high school,the guy used to buy them in wooden barrels.In the early 70's he still had a half dozen barrels left.The biggest things he showed me about installing them was to make sure there were no burrs,or lumps and bumps of any kind on both the drum and band.If there is a weld on the band make sure it is filed perfectly flat before you install it.
Old 03-07-2012, 07:12 PM   #4
Dusty
Dusty's Avatar
My drums are in very good shape cosmetically and the brakes works well until they are used frequently. Long grades and around town the brakes just seems to just go away and at times like these I have to stand on the peddle and I still don't think its going to stop.
As part of my winter project I looked hard at the brakes and found everything in very very good condition, the linings look to have even wear (and not much)and all the mechanics of the system look like the were rebuilt yesterday.
Old 03-07-2012, 07:12 PM   #5
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I have them on the front of the roadster and they don't have any noticeable brake fade. Good for many miles.
Barry B./ Ma. is offline   Reply With Quote
Old 03-07-2012, 07:19 PM   #6
VWJoe
VWJoe's Avatar
Did you check the inside diameter of the b/drums. If they are to thin
(0.060") then when braking, the heat causes the thin drum to expand (get larger) increasing pedal travel. The bands help limit expansion
Joe,,,
Old 03-07-2012, 07:57 PM   #7
Dusty
Dusty's Avatar
Joe,,,
Joe, I have not measured them but I highly suspect this is the problem, like I said when their cold they are pretty darn good but it don't take long for that to go away
thanks all...got my Snyder's catalog out as we speak however I must speak to the high minister of finances first(could be a long night)
dusty
Old 03-08-2012, 07:24 AM   #8
Patrick L.
Patrick L.'s Avatar
Steels drums are supposed to be .140-.150" thick and shouldn't be used [IMHO] if less than about .125-.130".. I believe Ford didn't want them turned/cut at all..
Old 03-08-2012, 07:32 AM   #9
VWJoe
VWJoe's Avatar
dusty
Dusty:
You can measure them yourself. You don't need any fancy b/drum mic. Just use a tape measure and measure across the inside of the b/drum diameter where the b/shoes make contact. It should read about 11.0" inches. If it shows 11.1/16'' inches (0.062" over), the drums are throw-aways. Remember, the two most important systems on any vehicle are the braking system and the steering system. You gotta be able to steer it and you gotta be able to stop it. Everything else is just frosting on the cake.
Joe,,,,
Old 03-08-2012, 12:03 PM   #10
Charlie Stephens
Dusty,
Remember that you will may have to have the drums turned after you install the bands. If you are over .060 on the diameter most shops will not turn the drums. It is good that they will not turn them because they are neither safe nor legal (in many states). No one mentioned that you cool the drums in the freezer and heat the bands in the oven to install them. They should drop right on.
Charlie Stephens
Old 03-08-2012, 02:36 PM   #11
Dusty
Dusty's Avatar
Dusty:
Joe,,,,
Joe I measured and they are right at 11 inches, also thanks to all.
dusty
Old 03-09-2012, 11:10 PM   #12
Paul_nz
Paul_nz's Avatar
I have installed a set on the front of my 28 Tudor, it did suffer from fade with the steel drums, but it is now so much better. I have yet to do the rear drums. I would certainly recommend the bands.
Paul_nz is offline   Reply With Quote
Old 03-10-2012, 09:49 AM   #13
Roger V
Roger V's Avatar
I have them on an A I did twenty-five years ago and they will stop as good as the two I have cast iron on. I don't recall the thickness on the steel but know they were not marginal. Besides adding thickness and rigidity, they disapate (sp.) heat. Besides making sure the flat mounted side of the band is burr, etc. free, I die grind the inner channel weld to match the contour. Looks better and may help with balance.
VWJoe's statement of braking and steering being the most important sytems on an A are absolutely true! That stone guard, step plates, etc. are not going to save your life....
Roger V is offline   Reply With Quote
