Old 01-04-2012, 09:56 PM   #1
wrndln
Default Riveting the patent plate on firewall
Does anyone have a good method to install a new patent plate on the firewall of a 28/29 with split rivets. I know it will take two people, one to press on the rivet head from the outside and one to installed it on the inside. The problem is getting to the split ends inside between the gas tank and the inside of the firewall. I am wonder what kind of tool would work best to bend the split ends over - just a regular screwdriver?
Rusty Nelson
Old 01-04-2012, 10:42 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Riveting the patent plate on firewall
Fine Point?? or driver. If driver, I would cut the rivit heads off and "glue" with silicone caulk the plate and rivits in appropiate place. JMO
Paul in CT
Old 01-04-2012, 10:57 PM   #3
Milton
Milton's Avatar
The proper rivet is the "nail-in" type. The rivet has an alignment shaft that is knurled at th top and that part drives into the rivet hole and holds the plate in place. One man operation.
Milton is offline   Reply With Quote
Old 01-05-2012, 12:46 AM   #4
Milton
Milton's Avatar
My bad, I should have qualified my answer with 30-31.
Old 01-05-2012, 09:41 AM   #5
dean from bozeman
dean from bozeman's Avatar
Rusty, the Judging Standards say, 'All rivets were installed with the rivet head on the engine side of the firewall.' However, I have seen several totally original A's that have the split rivet heads on the inside of the firewall.
My rebelious side says "Be Unique!". My fine point side says, "Follow the JS!". Personally I believe that the important thing is that all 4 rivets face the same way.
Dean
dean from bozeman is offline   Reply With Quote
Old 01-05-2012, 11:51 AM   #6
CarlG
CarlG's Avatar
Does anyone sell just the drive in type rivets?
Old 01-05-2012, 05:28 PM   #7
ora masters
Smile Re: Riveting the patent plate on firewall
yes SNYDERS NEW SPRINGFIELD OHIO 1 888 262 5712
ora masters is offline   Reply With Quote
Old 01-05-2012, 11:33 PM   #8
b ramsey
i also would like to know the answer to the original question.....
b ramsey is offline   Reply With Quote
Old 01-06-2012, 12:43 AM   #9
Mike V. Florida
Mike V. Florida's Avatar
Maybe taking a cheapo long screwdriver and bending it into an L shape, sharpen the tip. Sliding up between the tank and firewall, place the slot in the rivet, pushing in from front and twisting the screwdriver to open the rivet
Old 01-06-2012, 10:10 AM   #10
wrndln
Mike,
That sounds like an idea to try. I have four 28/29 A's, so if the tool works, I would have it for the next three A's I restore.
Thanks,
Rusty Nelson
