12-27-2011, 07:01 AM | #1 |
Banned
Longest doors???
Am trying to piece together a "phantom" (never made) body style out of discarded model A parts and am wondering which model A body style had the longest doors? 28-9 or 30-1 doesn't matter.
Thanks |
12-27-2011, 07:53 AM | #2 |
Re: Longest doors???
Well, since you are speaking of a phantom, it would probably be the 155C Wagon, or the 255C Delivery, which both shared the same door. They both were somewhere in the 48¼" range if my memory is correct.
Ohh, ...and "nice" username. . |
12-27-2011, 02:19 PM | #3 |
Longest as in height or width? Cause I thought a-400 doors were the widest.
Cowtown A's |
12-27-2011, 02:23 PM | #4 | |
How about the 180A door, that's a pretty wide door. |
12-27-2011, 02:27 PM | #5 |
180a doors are the longest ...
12-27-2011, 03:43 PM | #6 |
Banned
Ohh.... that has been my nick name for many many years Brent. |
12-27-2011, 07:10 PM | #7 | |
While it may be your nickname, I sure there are places where some folks don't say it outloud. In your defense, maybe you are never in those places. As for Victoria/400A doors, decent ones will generally set you back in the $800-$1000 range for the pair due to their rarity. Then you need to use a slant-windshield cowl section which are usually a little more expensive over a straight-windshield cowl section. While I am not condoning you building a hot rod or cutting up a car (since Ryan wants us to use this forum only for discussing Restoration, --not Rods), the easiest & cheapest method would likely be to find a pair of 'pre-May 1931' Fordor Sedan doors off of a Briggs and graft the two together, and then use sheetmetal to make the infrastructure where the wood originally was. More of those bodies around than will ever be restored. . |
12-27-2011, 08:36 PM | #8 |
try "tudor" doors ............ steve
V4f |
12-27-2011, 09:18 PM | #9 |
I think you should try to find some doors to make out of two like brent said. Since it is a phatom, you can make them how you like. Leave the a-400 doors alone and make two long doors out of some briggs doors.
Respecting and Resurrecting Ford Model A's. |
12-27-2011, 11:15 PM | #10 |
Maybe you thought they said, "JUNKNSHIT" , Maybe they said "JUMPINSHIP"
12-28-2011, 11:19 AM | #11 |
Banned
If I had 10 A400 doors, I wouldn't use one where it didn't belong. I am building this out of parts that were headed to the scrapyard after a nice trip thru the crusher. The doors I use will be junk also. Although, with the attitude I see about a name, makes me almost want to whack up restored A's.
Brent, As far as places I have or haven't been, not important, what I am is what's important to me. You don't see me passing judgement down. Thank you Steve. I appreciate the info, and I'll look for some junk doors. Last edited by Junknshit; 12-28-2011 at 11:37 AM. |
12-28-2011, 12:44 PM | #12 | |
And you choose a username that contains a word that most readers/posters here do not say/use publicly here. The real world is all about making judgment calls ....and you are correct that most won't see you passing judgment. I do however think your comment regarding how you would almost like to whack up restored Model A's says a lot. . |
12-28-2011, 01:16 PM | #13 |
Banned
WOW......................All I did Brent is ask a question about Model A doors.
It is plain to see that you have a problem with me. To put an end to this I will not post on this topic any more. |
12-28-2011, 01:39 PM | #14 | |
(I sent you a PM if you would like to respond.) Last edited by BRENT in 10-uh-C; 12-28-2011 at 02:18 PM. |
