Hi, Rich My 33 also has the narrow engine mounts and the front bumper brackets bolt only on to the outside frame rail, horns cut off. It also has the early front spring mount with the ears and with the braces that bolt to the inner fender panels. The inner panels look like yours. But it has no 7/16 brace bolt to the big fender brackets it has later brackets and skirted fenders. Is your ser. # higher or lower then mine. Are you in Eastern Washington. Thanks, Larry
