Old 10-24-2011, 02:24 PM   #11
BigErn
Default Re: Front end wobble
Hello Bobpo,
I had the same problem a few weeks ago and got a lot of great help from this site. Mine did not shimmy until I hit a bump. I checked everything for loosness and the only thing I could find loose was a sloppy steering box. I started to check everything in the Anderson book, and this is the embarassing part, it turns out that the tire pressure was low (like 10 psi) . I pumped the tires back up to 34 psi and wobble was gone.
BigErn is offline   Reply With Quote
