View Poll Results: Which years do you like best? (in other words, what style/look)
1928-1929 look 136 40.72%
1930-1931 look 198 59.28%
Voters: 334. You may not vote on this poll
Old 10-13-2011, 08:54 PM   #1
Mitch Bunkin in PA
Mitch Bunkin in PA's Avatar
Default Re: model a style 28-29 or 30-31
Hi,
As a novice, I just figured that all the "bugs" (if any) would be worked out by 1930 and I would have fewer problems that I didn't know how to fix. I also felt the original stainless lights, hubcaps & rad. shell would make it easier on me as I've seen that original nickel plated lights & shells usually need a lot of work to preserve. I also like the larger radiator.
WEBSITE=http://faculty.bucks.edu/bunkinm/
"Most people ONLY want to know
what they already believe and
nothing more."
Mitch Bunkin in PA is offline   Reply With Quote
Old 10-13-2011, 08:59 PM   #2
milo
milo's Avatar
28-29's do it for me......
You're born, you die, in between you build hot rods
milo is offline   Reply With Quote
Old 10-13-2011, 10:22 PM   #3
sturgis 39
Originally Posted by Mitch Bunkin in PA View Post
Hi,
The radiators are about the same size. The 30-31 is taller but narrower than the 28-29. The number of tubes and the number of fins and the material are the important issues. Copper "r" value is half (approximately) of aluminum.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
