Old 06-13-2010, 03:23 PM   #3
Richard (EV8G)
Richard (EV8G)'s Avatar
Default Re: Replacing axle seals 39 ford
Originally Posted by Tom/SC View Post
Check the differential filler plug to make sure that the banjo housing does not have too much grease in it. If it is at the proper level, it is not likely that too much grease would be pulled up...
Tom: I am pretty sure you did not mean to say "grease" but "gear oil"???
BTW: I have seen and presently have the "quick-fix" seal, which fits into the hole in the axle housing that the axel exits. I also have (somewhere) the source that I obtained them from. I have found them in rear ends that we worked on, but do not know how well they work. I am sure they are better than nothing though...
Early V8 Garage
Pasadena Roadster Club
Richard (EV8G) is offline   Reply With Quote
