Old 09-01-2011, 11:31 AM   #21
svm99
Default Re: Pilot Bearing options
I tend to lean towards the bearing myself based on the transmission side of things. As with Mac I agree the pilot end of the input shaft is a key part of good transmission operation as this end becomes the third bearing to align the input shaft which aligns the output shaft on which is mounted the heart of the transmission which is the synchro hub, sleeve and brass rings. i've disassembled many trans with a worn surface on the input shaft pilot which I believe is caused by a bushing. If a vehicle is stored in a dry environment a high quality bearing should work.
Always interesting to read other thoughts on these subjects.
Paul J.
svm99 is offline   Reply With Quote
Old 09-01-2011, 12:47 PM   #22
Krylon32
We've sold a bushing in our T-5 trans conversion kit for the past 15 years with almost no failures.
Krylon32 is offline   Reply With Quote
