Old 08-18-2011, 03:23 PM   #1
Slick Willy
Slick Willy's Avatar
Default 1935 Big truck chassis and parts
City: Marshfield
State: MA
Price: ??
I have an old 1935 big truck chassis, that is used and has been abused
I was going to use it for a franken-rod but it needs to go! I would like to keep the motor for some dumb reason, but the rest that has not rotted off is still there!
If you are local and need some or all hard parts make me an offer! I will try my best to remove what you may need, but I would love it if someone would come take the whole thing for a few hundred bucks!
The body on it is a 1925 Studebaker Duplex. If you want that make me an offer too!
**Sorry, grille is NOT for sale!
Slick Willy is offline   Reply With Quote
Old 08-18-2011, 04:12 PM   #2
Slick Willy
Default Re: 1935 Big truck chassis and parts
It also comes with the radiator, d.s. fender (not tooo bad), fender brackets, headlight bucket with brackets...
Just throwing it out there!
Old 08-18-2011, 05:12 PM   #3
Newc
Newc's Avatar
Hi all; I have cut up three trucks this year,after parting. $290 a ton prepared, no oils and nothing under 3'8" long. Most trucks average 1 to 1 1/2 ton of steel. Wheels fit 34 up. Some rodders want the tapered tie rods intact [not cut]. Universal joints are special, and the short half-shafts are an old racer part. Bellhousings are the 'hogshead' piece. Front wishbones are good tubing. ect. Newc
Old 08-18-2011, 06:12 PM   #4
sjselk
can you measure lug spacing
sjselk is offline   Reply With Quote
Old 08-18-2011, 06:32 PM   #5
sjselk
and hub diameter Thanks John
Old 08-22-2011, 12:37 PM   #6
NDTMAN
I would be interested in the rims also that is after you post the lug spacing you do this by measure between 1 and 3 lug hole center of hole to center of hole
NDTMAN is offline   Reply With Quote
Old 08-22-2011, 12:38 PM   #7
NDTMAN
and if these are the split rims with the outer split locking ring
Old 08-22-2011, 07:40 PM   #8
34Fordtk
34Fordtk's Avatar
Most likely by the looks of them they have the same one piece rings and the large BP as my 34 and 36 both have.
31 Coupe
34Fordtk is offline   Reply With Quote
Old 08-24-2011, 09:30 AM   #9
NDTMAN
Did you find if your wheels were servicable or were they the suiside wheels that tire shops will not work on???
Old 08-24-2011, 08:06 PM   #10
34Fordtk
34Fordtk's Avatar
I still have NO idea what Suicide wheels are, they have one piece rings not split rings. Sorry to the OP for the hijack.
31 Coupe
Old 08-24-2011, 08:39 PM   #11
NDTMAN
HERE IS A GOOD POST ON WHEELS
https://www.fordbarn.com/forum/showth...ht=BUDD+WHEELS
Old 08-24-2011, 08:40 PM   #12
NDTMAN
If you go to a tire shop they can tell you if your rims can be used
