Old 08-22-2011, 12:32 PM   #3
Bruce Lancaster
Default Re: 59A-B head gaskets
The gaskets are actually the design point controlling water flow distribution. Some holes are big for manufaturing reasons and coring, some may have been re-tuned with gasket work late in development.
The large gasket heads, 1938-42-WWII (trapezoidal holes near center) actually no longer have any application...if you look in the Ford '37-48 engine manual you will see that engines with the early heads were to have a couple of holes redrilled and then to be fitted with 59A gaskets when worked on. You should use the gasket with all round holes in the center.
