Old 07-31-2011, 11:53 AM   #1
mrtexas
mrtexas's Avatar
Default paint codes for engine green
Anyone know the PPG concepts code for engine green? Is rock moss green close?
mrtexas is offline   Reply With Quote
Old 07-31-2011, 12:39 PM   #2
Ken Ehrenhofer
Default Re: paint codes for engine green
I always buy my Ford Engine green from Hirsch Automotive products.
www.hirschauto.com
It is the closest I have seen and is also available from parts dealers but make sure you get the Hirsch product so it is correct.
If you want it in PPG Concept I would probably buy a quart and spray out a test panel and color match with you PPG dealer from there using Phrophet computer match,
Ken
Rock Moss green is another color completely.
Ken Ehrenhofer is offline   Reply With Quote
Old 07-31-2011, 06:07 PM   #3
Tony G
Tony G's Avatar
After reading around the internet at different engine restorers I just tried Rustoleum Dark Hunter Green. It matches my other engine that was done with the Ford paint almost perfectly.I also saved some money.
Old is good, New is bad. Very bad
Tony G is offline   Reply With Quote
Old 07-31-2011, 06:42 PM   #4
bobgreco
bobgreco's Avatar
Having just painted my truck gunmetal blue, I would say it is pretty close to the engine color, closer than rock moss green which would be too green. PPG will have a code for this color.
For what its worth, the right engine paint from Macs is only about $13 for a pint, which will do the engine more than once.
bobgreco is offline   Reply With Quote
Old 07-31-2011, 07:37 PM   #5
glenn in camino
glenn in camino's Avatar
I've posted this formula before, but its so good and so inexpensive, that I'll do it again
Rustoelum
2 parts hunter green
1 part royal blue
1 part gloss black
I painted the engine in my 1928 station wagon with this paint in 1973 and it still looks good.
Spray can Ford engine green is not very durable.
Old 07-31-2011, 07:58 PM   #6
mrtexas
mrtexas's Avatar
I'll post the formula tomorrow. I'm going the the local PPG guys and get a pint of urethane paint matched to the spray can of engine green I have.
Old 07-31-2011, 08:38 PM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Rustoelum
1 part royal blue
1 part gloss black
.....nor is it the accurate color either!!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
