Old 06-03-2026, 08:47 PM   #1
Stage1gs
Default 1931 Slant Window Drivers Door Spring Position
Hello everyone,
On a ‘31 slant window door latch (and maybe others) there is a spring that goes behind the door handle. When it is missing the door tends to lock itself when you shut the door. It looks like it can go in 1 of 2 ways.. with the spring coming out the front or the latch, or out the rear of the latch.
It looks like there should be springs in all 4 doors; if so, all of mine are broken and missing. For a given location in the car, how do you know which way the spring should be installed?
Attached is a picture of a door latch that could go in the drivers door. Based on this picture, is the spring installed correctly assuming the position is the front drivers side door.. aka the drivers door. Or is it backwards?
Appreciate any feedback and thanks in advance.
Brian
Stage1gs is offline   Reply With Quote
Old 06-03-2026, 11:15 PM   #2
JayJay
Default Re: 1931 Slant Window Drivers Door Spring Position
Originally Posted by Stage1gs View Post
Hello everyone,
Brian
Brian - Hate to be the bearer of bad news, but there is no way I’ve found to get that spring installed without bending the tabs on the back of the latch assembly and pulling the cover off. If you heat the tabs up with a pencil torch to red hot you might be able bend the tabs without breaking them, otherwise you’ll have to weld it back together. Once you get the cover off you’ll be able to figure out which way the spring goes.
This is not an uncommon issue as you might guess.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 06-04-2026, 06:47 AM   #3
Oldbluoval
Oldbluoval's Avatar
JayJay is spot on. Concur, don’t try to straighten the tabs cold…they will break. But u can weld back together as stated
