After not having much luck buying a good used pair of Edmunds heads, I'm considering a new pair of 8ba Navarro heads.H&H says they are one of the best flowing heads. Would love to hear from anyone who has experience or knowledge of them. Thanks.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
The Navarro heads that I have, in an engine supplied by H&H have the spark plug area too thick in the casting, about 4 threads to thick. The entire plug including the electrode is up inside the thread. The plugs get fouled every 500 to 1,000 miles. You can't put a longer plug in because the valve is too close. If he hasn't corrected this with the casting you will need to get some material removed.
"Shoebox", didn't you have a pair of Edmunds heads that needed some work? If you still have them, are they both unusable, or just one? In my never ending quest to find usable Edmunds heads, I have accumulated a couple of odd extras. I just bought a set with a good left (US driver) side and a cracked right head. If you still have them, perhaps we should discuss what we have and maybe we can come up with a solution to your problems. Best case, you come up with a good set of heads; worst case, I might buy yours to add to my pile of culls. I think it might be worth looking into, as I am convinced of the superiority of the design of the Edmunds units.
And "69a", that is troubling to hear about the Navarro heads. If true, it brings the quality of the entire design in question. I have never paid much attention to the idea that the Navarro's are "one of the best flowing heads" since with flatheads all of the ports and valves are in the block. In my book, getting the most compression without hurting the flow too much is is the main concern. This has more to do with quench and flame front travel than any esoteric contouring of the head surface. I would suggest trying to unshroud the plugs by using the longest plugs possible and some minor contouring of the heads around the plug. One other thing I might suggest is using the proper length "surface gap" plug. These are usually found in 2 cycle outboard motors. I had a 276 Merc with Offenhauser heads years ago that I couldn't get the proper reach plugs for. I ended up using surface gap plugs out of a 65 HP Johnson "Loop-Charged" triple that worked very well. That engine had a complete MSD ignition system, so I had enough oomph to fire the plugs. The only problem I had was that the spark was so hot that in a year's time, it burned through the coil wire tower, ruining the cap. Other than replacing the cap once a year, it turned out to be a great setup. Last edited by tubman; Yesterday at 01:14 AM. |
The Edelbrock heads appear to have CNC recesses around the plug area.
My Navarro heads do not. I can see down the the spark plugs hole that there is virtually no gap between the last thread and the exhaust valve (when fully open). Last edited by 69a; Yesterday at 09:01 AM. |
Navarro heads
#6 | |
#7 | |
"Tubman" pm sent.
#8 | |
I asked Mike about this subject, his response below. On Jun 3, 2026, at 9:23 AM, Mike Herman <[email protected]> wrote: The electrode is not supposed to hanging out in the valve pocket or it will hit the valve
#9 | |
#12 | |
Now that I say that, are you sure they weren't reworked for 3/4" plugs? New Edlebrocks are recast this way. |
#13 | |
#14 | |
#15 | |
#16 | |
#17 |
#18 |
#19 |
#20 |
