This question has undoubtedly been asked and answered many times; there are several different head gaskets available, which one should I use? And should I use sealant on it? This would be for an “B” motor with an “A” cylinder head. Thanks in advance
I recommend the BEST 509 copper gasket. They also make a fiber gasket, the thing I don't like about them is that when you have to remove it, you spend an hour scrapping the old one off. The 509 is an A gasket, do not use a B gasket as they may protrude into the combustion chamber.
I also use the Best 509, but I use the graphite version (509G) and coat with copper coat before installation. Yes, it’s a pain to remove, but that’s not a regular task.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#4 | |
www.whidbeymodelaclub.com |
509 copper gasket.
2024-2026 MAFCA Technical Director |
A Model Aer on our recent rally blew a head gasket. Before retirement, he was a mechanic so replacing it was no problem.
I'd like to know what others think of his use of grease on the gasket before he tightened it down. He said he has done it that way for years.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say. I sometimes wonder what happened to the people who asked me for directions. If I am not in trouble, I've done something wrong. |
Back in the 1950s working on Model As and V-8, that was the norm.
I have heard of it being done but I have always used high temp gasket sealer. I guess if it used to work, it will still work.
#10 | |
I suggest you use any of the Best brand head gaskets.
Bob Bidonde |
The one question that has not been discussed above is has this 'B' Block been modified for using an A head on it?
#13 |
We always used the copper clad gaskets, not the steel ones.
Later years some people used a thin coat of spray aluminum paint and let it dry before installing.
#14 | |
#15 |
Would the aluminum spray paint work on a graphite type head gasket like the 509-G?
