Old 04-29-2026, 08:05 AM   #1
Ron_r1959
Ron_r1959's Avatar
Default converting a columbia overdrive from vavcumn shift to electric shift
I have a 48 Columbia overdrive that I am rebuilding to put in my 41 ford pick up, I am wondering if anyone has information on converting it to a all electric shift similar to a two speed reared on a truck and eliminate the vacuum parts on it. I would assume someone has done it at one point or another using a electric actuator. Thanks Ron
Ron_r1959 is offline   Reply With Quote
Old 04-29-2026, 12:51 PM   #2
wga
wga's Avatar
Default Re: converting a columbia overdrive from vavcumn shift to electric shift
Ron, i had the same thought, use a electric actuator, since I worked for a company and we made them...12v linear actuators are common and very reliable, if you source it correctly. Need to know the stroke length, usually in 2 inch increments, and the force required. Speed is also a consideration, the greater force, the less speed.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 04-29-2026, 02:22 PM   #3
big job
big job's Avatar
two speed Eaton axle actuator the whole unit should work even the 6vt ones. Been a
while but when the motor spins and hits a dead stop it will stop dead. now the next
time it is switched the motor will reverse until it hits a dead stop. that is done by a
switch in the housing so you need the switch Napa has that switch with red button and the internal reversing switch in the housing.....
e
big job is offline   Reply With Quote
Old 04-29-2026, 03:34 PM   #4
Hitman
Why not convert it to a cable operated shift? I believe that's been done successfully for years.
Hitman is offline   Reply With Quote
Old 04-30-2026, 07:23 AM   #5
fortyfords
fortyfords's Avatar
Electric would sure beat those vacuum tubes and the vacuum valve and even eliminate the worry about keeping the vacuum can lubed. Looking forward to a solution by you guys.
fortyfords is offline   Reply With Quote
Old 04-30-2026, 08:26 AM   #6
glennpm
glennpm's Avatar
I have a 37-41 Columbia on my '40 rearend in my '32 roadster. Pic below is a mechanical setup https://fifthaveinternetgarage.blogs...overdrive.html
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 04-30-2026, 08:39 AM   #7
pistonbroke
One thing to keep in mind is how to keep the axel sealed up after removing the vacume unit. Iorn trap garage made a manual opperated Columbia a while back so a electric one should be doable. The actuator will need to be two way, both push and pull. It will also need to be fairly strong as it takes a little force to move the control arm by hand. I had a Columbia in my 38 Zephyrthe aluminium part of the vacume unit was broken do to an impact at some point so I to was looking at possible conversions.Tim
Old 04-30-2026, 09:00 AM   #8
Dave/Green Bay
Here's a post by G.M. from years ago
"I made my own shifting controls. I don't like the way
the original ones work. I use 12 volt Pollock fuel shift valve
that is made for trucks with dual fuel tanks. As I described
I shifts by pushing a button and pushing the clutch. The
12 valve works on 6 volts. Pollock calls this a 6 port shifting
valve. G.M."
Dave/Green Bay is offline   Reply With Quote
Old 04-30-2026, 11:52 AM   #9
Ray in La Mesa
I made a bell crank shifter like glennpm's for my '28 A roadster p/u in 1973 and it's still shifting great.
Ray in La Mesa is offline   Reply With Quote
Old 04-30-2026, 12:11 PM   #10
glennpm
glennpm's Avatar
Can you post some photos of it Ray?
Rumble Seat’s Notes
Old 05-01-2026, 12:04 AM   #11
Ray in La Mesa
Sorry, I haven't figured out picture posting yet.
Old 05-01-2026, 05:29 AM   #12
glennpm
glennpm's Avatar
Hi Ray, some instructions on posting pictures. First time can be a little confusing :-)
Posting photos:
https://www.fordbarn.com/forum/showt...posting+photos
https://www.youtube.com/watch?v=CGijbl1bfnIhttp://
File Type: pdf Posting Pictures & Attachments on the Barn.pdf (1.05 MB, 8 views)
Old 05-01-2026, 07:51 AM   #13
jimTN
I have two 34s I set up using the original vac cyl and the shift valve and cable from a 50s GM two spd trk. They work quite well. I mounted the push pull cable and button right on the gear shift levers.
