#15 |
I made a new plate to hold the pertronix moduel from an old 6 cylinder singel point plate or something, I moved the moduel for more advanced, the cast alloy plate use to bind and and cant be adjusted like a steel one by bending the bush holder.
Now the engine runs smother and sweeter and has way more power than before and it runs cooler. I promise you there is not enough advance in the Petronix unit with out slotting the distrubtor body or moving the moduel |
