Old 07-22-2011, 01:16 AM   #11
Barn Junk
Barn Junk's Avatar
Default Re: Transmission prices
The 78 cases with the most room and the strongest are from the 41-52 pickup light duty top loader 3-speeds. They usually had the 29 tooth cluster and that was what the extra space was for. Putting the 29 tooth cluster in the 18 case is a challenge and may even require a little grinding cleanup in the bottom of the case. The 46-52 pickups, floor and column shift, used the same syncro with the clips.
Barn Junk is offline   Reply With Quote
