Old 12-26-2025, 11:04 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: 1932 Brake Housing Plate Centering Bracket question...
Originally Posted by Terry,OH View Post
If the part that is broken is riveted to the backing plate I suggest getting another backing plate and replace!
Thank you for your advice but honestly, I don't see the logic. What am I missing? Why not repair/restore instead of replacing it with another Plate with potentially the same worn part?? At that point, would we really gain anything?
And for the others, thank you for trying to assist us. For some who are still curious what I am referring to, I have included some pictures. As I commented on above, while the description states they should work, the Model-A units are not exactly the same. We can modify those if need be, but I just wanted to make sure that replacement units for the '32 Plates were not available. I also included the factory drawing of the front Centering Plate that does appear to be the same as the Model-A units.
File Type: jpg A-2017 Front Brake Shoe Centering Bracket - Roller Tracks2.jpg (48.0 KB, 185 views)
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
