Old 12-03-2025, 09:37 PM   #41
Eodcoduto
Default Re: 1941 Special Sedan
The more I think about it, I bet the steering box isn't frozen, the column lock is just doing its job. Anyone make keys?
Eodcoduto is offline   Reply With Quote
Old 12-04-2025, 06:59 AM   #42
Ggmac
Yes , there is a member here that does an excellent job with keys . Someone will have his name . I can’t remember it. Great job on your recovery. I personally love the 41s and have 3 currently. I’ve got some nos doors and front fenders . Just as spares but hopefully I’ll never need them.
Old 12-04-2025, 08:08 AM   #43
corvette8n
corvette8n's Avatar
https://www.fordbarn.com/forum/showthread.php?t=46583
32Phil can make a key for you, he made my ‘41 from the numbers on the passenger door lock.
Old 12-04-2025, 08:23 AM   #44
Eodcoduto
Thats great.
Old 12-04-2025, 06:09 PM   #45
Eodcoduto
Doesn’t look like I’m gonna be able to vice grip garage this one, I can get the crank to turn a few degrees and three of the pistons on that side move up and down. The one with all the water damage does not move at all so it has a broken crank or a bent rod.
Old 12-04-2025, 07:10 PM   #46
petehoovie
petehoovie's Avatar
Originally Posted by Eodcoduto View Post
Doesn’t look like I’m gonna be able to vice group garage this one I can get the crank to turn a few degrees and three of the pistons on that side move up and down the one with all the water damage does not move at all so if you got a broken crank or a bent rod.
Old 12-09-2025, 10:05 PM   #47
Eodcoduto
I got the oil pan off of the flathead, and it’s amazing that every bolt came out easy, caked in dirt and grime. Nothing broke off or has been stuck. The reason it was parked is they ran it out of oil. You can move the crankshaft and the rods up and down About a 16th of an inch so I’m going to pull it out this week and see what the true damage is.
Old 12-09-2025, 10:25 PM   #48
tubman
tubman's Avatar
It looks like nothin' went through the block; thank heaven for small favors. The rods that we can see look like they got pretty hot, though.
Old 12-09-2025, 10:37 PM   #49
Eodcoduto
Yea they did, my bet is it started knocking and they pushed it until it died or got them home
Old 12-10-2025, 12:39 AM   #50
petehoovie
petehoovie's Avatar
Old 12-13-2025, 09:54 AM   #51
65f100
65f100's Avatar
thats an awsome car..good luck with it
65f100 is offline   Reply With Quote
Old 12-13-2025, 08:05 PM   #52
Eodcoduto
Pulled the engine today and got the stuck piston out, the rod bearing came out in multiple pieces but the journal nor the rod are scored. The engine spins now without any stuck valves but the bores are rough. This has a 3 ring dome piston, were these stock?
I’ll finish teardown this weekend and mic everything to see what the damage is.
Old 12-13-2025, 09:24 PM   #53
petehoovie
petehoovie's Avatar
Old 12-15-2025, 04:24 PM   #54
Als48
I think the original pistons had 4 rings each. Did you find any stamped numbers on the piston tops to indicate oversize pistons?
Als48 is offline   Reply With Quote
Old 12-15-2025, 08:21 PM   #55
sugarmaker
sugarmaker's Avatar
Looks like you have a nice shop where you can work on your car. Will be watching as you make progress.
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
1966 Ford F100
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 12-15-2025, 10:35 PM   #56
Brian
Brian's Avatar
That is a steel piston...some engines were equipped with them. All the steel pistons were of 3 ring configuration. And your block has steel sleeves too.
Old 12-15-2025, 11:24 PM   #57
Eodcoduto
They are and I knocked the liners out yesterday, the bores are in good shape.
Old 12-16-2025, 01:26 AM   #58
ford38v8
ford38v8's Avatar
Looks like the block has the so-called raised deck. If I recall, that might indicate the block could be the original for the car.
Alan
Old 12-16-2025, 07:32 AM   #59
Eodcoduto
I assume it is the original engine but no way of proving it. Its the right generation.
Old 12-18-2025, 07:33 PM   #60
Ggmac
If its std bore I would like to buy a couple of pistons ,pins and locks .
Shouldn’t that have floater bearings ?
