Old 12-08-2025, 04:17 PM   #13
jimTN
Default Re: 1932 Rear End Rebuild
Brent, One of the weakest points of the early 32 axle is the driveshaft bearing behind the u joint. I believe the roller bearing and sleave is the same as an A. If the shaft itself is worn, you may have to cut a section from a A shaft and the B shaft to repair it.
